Ana içeriğe geç
Repair guides for the MacBook.
3787 Soru Tümünü görüntüle
Soru Kapandı
How diagnostic from usb key?
Think my logicboard is dead, black screen, just HDD who is power on nothing else, opical drive do not respond at all
How to realize an hardware diag from external usb key cause to put "D" key at startup do nothing
thks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum
I'm not sure I understand. Your symptoms point to a dead logic board, but what are you attempting with USB?
tarafından
With 24h, no changes, I have power cause I can heard the Hard drive power up
Think its logic board definitivly
thx
tarafından
yes and no chime even if I keep power button on during a while...
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Grasping at straws here...
You could try removing the battery, unplugging the power, and letting it sit for 24 hours and see if that brings it back to life.
I assume you're not getting the startup chime? If you are, there are other steps we could offer.
Have you considered it may not be getting enough power? Do you have access to another power adapter to try? Try it without the battery installed.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I hope an usb diagnostic tool in order to confirm if logic board is dead or not cause I m not confortable to buy another logic board just for fun !
Puan 0
1 Yorum:
Unfortunately if the logic board is bad the USB ports most likely will be dead. Ralph
tarafından
Yorum Ekle
thx
Puan 0
1 Yorum:
No chime? Just hard drive spinning?
tarafından
Yorum Ekle
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 913
