Voltage of Power suply output and of DC-DC board
Hallo
do someone know the Voltage of the output from power suply (black = 0, grau = 12V ? , brown = ? )
and the output from the DC - DC board?
Thanx
Bu iyi bir soru mu?
Hallo
Thanx
Bu iyi bir soru mu?
Hi, this URL mainly covers the repair of capacitors but if you scan down to page 13 there is a pinout of power supply connections. Hope this helps. Ralph
Bu yanıt yardımcı oldu mu?
forget the power supply right now, check the dc/dc board, if you don't have the proper voltages there then ck the power supply.
looking straight into the dc/dc female plug...
onA - Grd-12vR -(?) -5.0vR -3.3vR
(?) - 12v - 12v - 5.0v - onB - 3.3v
the ? pins are probably grounds as well, but I'm not 100% sure - the 'R' voltages are only on when the power A and B pins are touched together ie. the computer is on
Hi, Thanx for help, but this is not the power supply of the model A1144, it's from the other G5-Model (A1058), I could not find anything about the A1144 on this page.
I was hoping the color id's for the different voltages would help you identify your supply voltages. Usually they use the same color codes.Good luck with your problem. Ralph
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 5
Her zaman: 3,453
