Ana içeriğe geç
Sony tarafından üretilen MDR-ZX100 ZX Serisi stereo kulaklıklar.
Both the speakers are not working
Both the speakers are not working and I have checked the whole wire and it is working for another speaker and I have connected the speakers with another wire it not working...hence the problem is with my speakers. Please help
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
nitheesh k unlikely that both speakers have failed. Check the 3.5mm plug. Check it and replace it as necessary, follow this guide Skullcandy SCS-SCBP SKULLCRUSHERS 3,5 mm konnektör tamiri to do so. Different model headphone but identical procedure. you can also check the wiring to the drivers (speakers) by using this guide Sony MDR-ZX100 onarımı and measure continuity with a multimeter from the connector to the drivers.
Skullcandy SCS-SCBP SKULLCRUSHERS Görseli
Kılavuz
Zorluk:
Orta
45 minutes - 1 hour
Sony MDR-ZX100 Görseli
Kılavuz
Zorluk:
Orta
15 - 30 minutes
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
The problem is most likely with your speakers, but it is unusual that both speakers fail together. Are these speakers connected to a computer? Such have a power supply inside one of them and if that fails the speakers do not work. As most of these have an external wall-plug supply, check this (measure voltage at the output plug). If there is no voltage just replace the "wall-plug" supply with one of the same voltage and Ampere rating.
If your problem is with regular speakers that you connect to am amplifier I have no idea what may be wrong with both of them.
Puan 0
Yorum Ekle
Yanıtını ekle
nitheesh k sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 15
Son 30 gün: 24
Her zaman: 387
