Ana içeriğe geç
Performance Designed Products, LLC tarafından üretilen, 064-015-EU-BL model numaralı PlayStation 3 kablosuz LED kontrolcüsü.
USB Not connecting to PS3
My PS3 afterglow controller has always worked great but recently the USB drive just stopped connecting. Now whenever I plug in the USB to my system it just continuously blinks. My USB ports are working fine because I can still charge other controllers and the actual USB to the controller connects perfectly fine to my PC just not my PS3. So I have no clue what the issue is and I don't quite want to get a new controller yet because it seems like this one still works, it just isn't connecting to my PS3 right now. It'll be great if someone could answer this
Bu iyi bir soru mu?
Puan 4
1 Yorum
how u dont use the usb for ps3 and pc
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Check the pins on the controller's end of the USB. Are any of them bent or dirty? A short due to a bent pin or dirt blocking a connection could be causing the issue. It also would not hurt to give the controller's usb pins a cleaning with contact cleaner to ensure a clean connection. I would also recommend checking the cable itself, to see if their are any kinks in or exposed wiring. If that doesn't it fix it, then its most likely a problem within the controller's PCB board.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
What is a pcb board and how can i fix it or clean it so i can get the controllers to work
tarafından
Yorum Ekle
Yanıtını ekle
Ty Smothers sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 38
Her zaman: 12,714
