Spanner broken and stuck on dremel
My dremel spanner is stuck inside the dremel. How do I remove the broken piece so i can replace it so it will grip the bit again when I tighten the collet nut on?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Britain and America Are Two Nations Divided by a Common Language
I though a spanner was a wrench. If this is a broken bit stuck in it, completely remove the collect to take any pressure off. Then usually a small thin flat head screwdriver can be inserted and the bit pushed out.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 344
