Ana içeriğe geç
Released in 2005. Model number: PP11L, Imput: 19.5V ~ 4.62A.
14 Soru Tümünü görüntüle
My Dell D610 power light comes up and turn back off.
please help me to how do i take care of my laptop that turn on power and turn off back...
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
What happened before this? Have you tried removing the battery and just plugging it in? Are you using an original ac adapter/battery? Has any work been done before it broke? Do you get any beeps or blinking lights? How long does it last before it turns off?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Try removing the battery and then boot up using the ac adapter. See if the keyboard lights flash and if the Dell splash screen appears. If the system turns off immediately, the problem is a bad motherboard. It may be getting a false indication of over heating which will turn the system off to protect the processor. It also could be a power management problem. The over heat detection and power management are built into the motherboard.
If you get a beeping noise, count the beeps and let us know. There are several beep codes that indicate what has failed. This would indicate that the motherboard is good but a component such as memory has failed.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Abiola sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 6
Her zaman: 463
