Ana içeriğe geç
The OP-1 is a portable music workstation incorporating a synthesizer, sampler, sequencer, multitrack recorder, drum machine, mixer, and controller. It was released in 2011.
Why won't audio come from the right channel of my OP-1?
I have made sure that all the tracks are panned towards the center, but no audio comes from the right channel. If it is plugged into speakers or headphones and panned to the center, audio only comes from the left side. If it is panned to the right no audio come out. I was curious as to if there is something I am missing or if this is a hardware problem that requires repairs/parts. Thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You most likely have your External sync set to pocket operator sync. See section 10.7 in the Op-1 manual. It uses the right channel to send sync data, therefore no audio will come thru. I did this once already and was baffled for a few days, I almost bought a new board even!
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
If the above doesn’t work try wriggling the jack in the socket to see if the contact has come loose from the control board. If it has come loose, you may need to re-solder the audio output component’s contact(s).
Puan 2
1 Yorum:
Hey there, im a newbie when it comes to soldering, I’m a welder so I’m underdstand the most basic principle of the whole thing, but one question i do have is, are the cheap soldering irons you can get at wal mart any good for an application such as this? I would hate to go to resolder some contacts and melt the board or short something out on accident, its my understanding that this job is already marginally harder than other common soldering jobs because the connector board doesn’t have through hole architecture, or maybe it does and I’m mistaken, anyway, you can tell i dont know a whole lot lol, thanks in advance for any help you can give
tarafından
Yorum Ekle
I resoldered mine with a decent iron and yeah it’s quite difficult because of the component size and proximity to other components. Even with a decent setup I made a bit of a mess. I’m used to welding too haha. If you’re able to do it you can save $50+ on a new control board. If you’re not comfortable the price for a new control board can be worth it. That said, it’s worth a shot. What are you going to lose if you mess it up with a cheap iron? If you get it right you get a functioning OP1. If you mess it up you have to fork out, which is what you’d have to do anyway.
Puan 0
1 Yorum:
Hello Shem ; on my unit the audio out got a little bit out of the board, so pushing with a finger makes it fine, I think I will try to resolder it if fail, I will get a new board.
Thanks for your comments
tarafından
Yorum Ekle
Yanıtını ekle
Ben sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 44
Her zaman: 2,417
