Ana içeriğe geç
Model A1288 / 8, 16, or 32 GB capacity
451 Soru Tümünü görüntüle
Do I remove the plastic film from the replacement front panel?
On the back (inside surface) of the replacement front panel for the iPod Touch 2nd Generation, I have found that there is a plastic (protective?) film. The plastic film has a tab that extends underneath the front panel data cable. The tab seems to be begging to be grabbed to remove the protective film.
Do I remove this plastic film from the back of the front panel prior to installation or will that destroy the touch screen?
Thanks,
Jeff G.
Bu iyi bir soru mu?
Puan -1
1 Yorum
Yes, you do want to remove it. LCD's get those as protective covers prior to being shipped. good luck
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
yes remove it. there should be a little tab, be careful not to pull off the digitizer. the plastic you are talking about should have a little die cut mark around it, am i correct?
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Yup, that's the one. Silly me had that on for 6 months...
tarafından
but I bet your screen looks brand new :) best wishes...
tarafından
Yorum Ekle
Alright, but can we actually get a real answer about the repercussions of leaving the film on vs removing it?
I always remove them, but am just curious to what would happen if you don't.
Puan 0
Yorum Ekle
Yanıtını ekle
Jeff G sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 9
Her zaman: 7,619
