Ana içeriğe geç
The Asus VivoBook X202E is a small laptop released in late 2012. It has an 11.6-inch touchscreen display and a 3rd-generation Intel processor inside.
23 Soru Tümünü görüntüle
ASUS F202E-CT148H 4GB 1333Mhz to 8GB RAM replacement performance?
My ASUS F202E-CT148H laptop performance is very slow so, I am thinking to upgrade the 4GB 1333Mhz ram to 8GB i.e 4Gb in each slot. Will it increase the performance of my laptop ? Also which brand RAM will give good performance and Do I need to buy low voltage RAM or other.
Please do share the link of RAM which I can buy online in India.
Any inputs will be appreciate.
Thanks,
Yogesh
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Here’s how to upgrade the drive:
https://www.jdhodges.com/blog/asus-x202e...
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Doubling your RAM would only produce a 20% to 33% speed increase. Your bottleneck is at your hard drive. Either switch to an SSHD or SSD hard drive, which would more than double your speed.
Puan 2
Yorum Ekle
@avanteguarde
Sorry for late reply and thanks a lot for your help.
Which RAM and SDD I need to buy to upgrade ?
I figured out that this ssd is compatible with my laptop , Please correct me if I am wrong ?
RAM I am not sure, if you don't mind can you please let me know the amazon.com US url for compatible RAM.
Puan 0
2 Yorum:
@avanteguarde
tarafından
For the SSD, you are looking for the SATAIII interface (the largest physical size). The samsung's are the most popular. However, if you plan to get an WD blue, look for a Sandisk X400. This is exactly the same drive, but still includes drive encryption security that WD removed when they purchased Sandisk.
tarafından
Yorum Ekle
Yanıtını ekle
Yogesh sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 2,253
