Ana içeriğe geç
Vw golf Back lights
Hi I have a 2005 golf tdi I'm pretty shore I have noticed lately going out to it early in the morning to go to work the back lights are on all other lights are off car is locked I was on Night shift when I noticed them turn on about 12 am opend the car made shore everything was off and can't seam to get them to turn off any one experienced similar issues ??
Bu iyi bir soru mu?
Puan 0
2 Yorum
The back lights! Not the brake lights!!! The red lights behind the controls stay on (power door locks; side mirrors; dash lights; etc. Causes my battery to die also. So far nobody has answered this issue for many
tarafından
Did you find a solution for this? I seem to have the same problem on my 2005 golf
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Check the brake-pedal switch. This small button behind the brake pedal is activated when you press down on the brake pedal and makes the brake light go on. Press the switch by hand to see if it's stuck. If it is, pressing it may force the stuck part.
Find the fuse for the brake light and pull it out. Remember to put it back in before driving again
Find the brake lightbulbs and remove them. Remember to put them back in before driving again.
Disconnect the negative battery cable. You will have to reconnect it again to start and drive your car.
If that doesn't work, try a new relay switch.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Jordan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 44
Her zaman: 10,126
