Ana içeriğe geç
The Samsung Galaxy A5 (2016), an Android Smartphones released by Samsung Electronics in 2016.
58 Soru Tümünü görüntüle
Flashing Samsung logo after phone tried to restart
I tried to unlock the phone by fingerprint after pressing the power button but the phone was unresponsive. I tried turning th e screen on and off by pressing the power button to bring me to the lockscreen. it was still unresponsive. The phone turned off and the next thing is the samsung logo appears and it keeps flashing. Please help.
Bu iyi bir soru mu?
Puan 5
Yorum Ekle
6 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hello, I have also had this issue before.
I tried every way of rebooting. Have you tried rebooting by holding the power, home and volume down button for a while?
If this doesn't work, it's likely your phone has a software issue. You will have to go to an android repair store or your service provider store and they should fix it for free.
Bu yanıt yardımcı oldu mu?
Puan 7
2 Yorum:
i cant boot the phone, when i press boot volume up, nothing happens,if i press volume down,it gives me a warning and i cant even move at that step. After 5 sec, it closed and continue automatically flashing on logo.
What is the problem?
tarafından
I have this problem where my phone is locked and i cant remember the pin as not used in a long a time its a Samsung Galaxy Tor and when i hold down the power button and the volume down key the whole screen flashes for a little bit then the Samsung logo appears and its still locked what can i do please as it doesn't bring up the setting to wipe the phone amy ideas please i need help to unlock it
tarafından
Yorum Ekle
It happened again. I pressed the volume down, power button and the home button and the phone restarted. The phone is working now
Puan 3
2 Yorum:
Flashing and couldn't turn off and on again. Found this and it work's. Very relieved
tarafından
I did the same , hold all three buttons down at once and it turned on working fine.
tarafından
Yorum Ekle
Thank you for the reply.
The phone is working now. Since the battery is non-removable I waited until the battery drained it self then i plugged it in and switched it on. Its working now.
Puan 1
Yorum Ekle
i had a samsung galaxy j4+ phone from 02 last year.i got plugged in the usb logo name flashes on & off.But it wont go on homescreen to start.The battery was low less than 1%.if its flashing now.Does that mean its charging the phone up. Mr Nigel Jones Wrexham north wales.
Puan 0
2 Yorum:
The Samsung Galaxy 84+ phone is on contract from 02 last year.it cost £150 with a gold casing
tarafından
Hello @nigeljones I have the exact same problem, did you find any solution?
tarafından
Yorum Ekle
I am using galaxy a70, and suddenly my phone screen stopped working. I can take calls but screen is not visible but phone is working, and when I am pressing volume down and power then samsung logo is flashing, I am helpless even I went to Samsung care they said it's a display issue which I don't think so, I don't know what to do further. PLEASE HELP ASAP
Puan 0
Yorum Ekle
Hey guys
I am having the same problem
I tried Home, Lock, Volume Down and it asked regarding the OS.
I confirmed yes and it said OS is downloading, do not turn off target.
Its been stuck on that screen for the past 2 hours.
Any more ideas guys? I do not want to take for repairs as it will wipe all my data.
I have not backed up anything
Puan 0
2 Yorum:
To fix that press volume down and power button it should restart the phone and go out of it
tarafından
My phone is giving the same trouble and I'm getting the same green screen saying downloading do not turn off target. Pressing the volume down and power button removed the green screen but the screen is black and the phone won't turn on. What do I do?
tarafından
Yorum Ekle
Yanıtını ekle
edem sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 41
Son 30 gün: 177
Her zaman: 28,157
