Ana içeriğe geç
"Dünyanın en küçük 15,6 inç dizüstü bilgisayarı; yüksek performans ve çarpıcı InfinityEdge ekranı, Dell'in şimdiye kadarki en güçlü XPS dizüstü bilgisayarında bir araya getiriyor."
How do I replace the audio jack?
My audio jack is faulty. Can't afford a new motherboard. Where can I find a replacement audio port?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
2 Yorum:
Actually, the XPS15 9550 is barely or under a year old. Dell should replace it for free. IF not, check the credit card you purchased with, and they may cover the warranty for an extra year.
tarafından Paylaş
It has a broken headphone jack stuck in it. Dell said it won't be covered under the warranty period as its negligence/damage.
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
The audio connector is part of the mother board. Unfortunately, Dell has decided that this problem is not warrantable. You may be in luck if the problem is a broken off part of a head phone jack and not a broken connection on the mother board. You may be able to remove the boken head phone part by using tweezers or use a paper clip bent into a small hook to pull the broken part out. You may be able to find a computer repair shop that can do this for you. Worst case is you may need to use a USB type audio head phone. Good luck
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Ketan Krishna sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 1,674
