How to reset frp
How to remove frp from nexus 5x
Bu iyi bir soru mu?
Where are you located? Also there are ways to bypass it. Check if you can click on share when highlighting for example the wifi password enter in with show password for example.
I'll walk you through on what I mean.
So when you are on the welcome setup screen go to the page that prompts you to connect to an wifi network.
On that screen you will want to select a network then type some characters in then tick the box show password.
Then you tap and hold on that password entered and then click on share. There you will want to type in chrome and select the chrome app.
If you can do that then frp lock is easily bypass able on there.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 1,963
1 Yorum
YOU CAN TRY THIS METHOD WITHOUT PC
https://frpbypass.net/bypass-frp-nexus-5...
abouza ucf tarafından
