Ana içeriğe geç
Dell Dimension 4700 masaüstü bilgisayar, 2004 yılında Intel Pentium 4 İşlemci, DDR2 RAM ve Windows XP işletim sistemiyle piyasaya sürülmüştür.
Can I fix a boot up error?
Receive the following message upon boot up attempt: windows root file missing, need to install windows root file<windows root>\system32.\hal.dll
My question is: can I do this and where do I find the file? Thank you
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Depends on your version of Windows. If you can press F8 a bunch at boot and get into Safe Mode, then you're not totally rooked.
The file can probably be found on your Windows cd and might be named hal.dl_ (just renamed it)
If you boot off your Windows CD and try to install to C: again, it should also prompt you to do a repair instead. (Not repair console - repair reinstall)
If you don't have a Windows CD and just have a manufacturer restore disk, this usually wipes the hard drive.
Either way, do a Scan Disk once you get your computer working again.
The good news is, your data's probably still there, and a tech savvy friend/family or a computer shop should be able to pull it off onto DVDs or an external hard drive.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Here is a link to some things that you might be able to try to fix it.
http://pcsupport.about.com/od/findbyerro...
Let us know if one of these works!
Puan 1
Yorum Ekle
One of the first action to take in case you have difficulties with the MSVCR100.DLL file will be to examine whether you are utilizing a 32-bit or 64-bit Windows version.
Useful article about this http://www.msvcr100dll.com/
Puan 0
Yorum Ekle
Depends on your version of Windows. If you can press F8 to bunch at boot and get into Safe Mode, then you're not totally rooked.
Cd and might be named hal.dl_ (just renamed it)
If you boot your Windows CD and try to install C: again, you should also prompt (Not repair console - repair reinstall)
Puan 0
Yorum Ekle
Yanıtını ekle
gdbtrbst2u sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 24
Her zaman: 2,198
