How can I unlock my iPod
My little sister was play with it and lock it. I forgot my combination and can't unlock it.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Here is a link to Apples procedure for setting and removing the lock. Please note you will lose all your data. Good luck.
Bu yanıt yardımcı oldu mu?
rj713 is of course absolutely right. There is a also another way to reset it without losing the data from your ipod :
first plug in the ipod, go to my computer, click on the ipod drive. Go to tools > folder options then click view. Click show hidden files,
Go to ipod_control, then go to device. There should be a file named "_locked" delete that. Now unplug the ipod and you should be ready to go
Good luck
didn't work so don't konw
it did not work
This Helped Alot Thank You
It worked for me thank you a lot.
Go to Ipod folder in computer make sure hidden files are displayed
go to
-ipod_control
--Device
---_locked
don't delete it, just change it to un_locked
worked for me many times, just don't know how to full remove code or change it without restoring ipod
Telling her how to show the hidden files would greatly improve your answer.
This actually worked for me! In explorer go "View > Hidden Items" and uncheck it. Then go to the folder "IPod_Control" and do as described above.
Son 24 Saat: 4
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 15,228
2 Yorum
ive down loaded some music and turning it back on its showing the padlock feature and i cant unlock it ...how do i unlock it
bernard tarafından
It may also be called _volumelocked
Simon Pugh tarafından
