Ana içeriğe geç
5. nesil Honda Accord coupe, sedan ve station wagon modelleri için onarım kılavuzları ve destek.
Speedometer works when it wants
speedometer works when it wants RPM gauge works just fine. could the wires on the sensor be loose? Where is the sensor located? 1995 Honda Accord 5 speed thank you
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Best bet is to replace the speed sensor . You need to remove the air cleaner and look down on the back side of the motor where the motor meets the gearbox . Under the distributer and the water hoses on the gearbox
http://breebamboo.ipage.com/archive/imag...
Hope this helps
Bu yanıt yardımcı oldu mu?
Puan 4
1 Yorum:
Is this in the same location for a 95 Accord LX, Automatic 2.2L?
tarafından
Yorum Ekle
There's a good chance your speed sensor is going bad, specifically the speed control sensor. I had the same issue in mine. So...what Jimfixer up there said
Puan 0
Yorum Ekle
Yanıtını ekle
Barbara Edgman sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 1,671
