Ana içeriğe geç
Device and repair information for the Dell XPS 13 laptop models 9343 and 9350, which were both released in 2015.
75 Soru Tümünü görüntüle
Replacing stock thermal compound
My recently bought Dell XPS 9360 with the 4k screen, Intel i5 7200U is idling around 55 degrees celcius. Browsing reddit I see that some people have suggested replacing the stock thermal compound on the heat pipe (source). Has anyone else tried this out to succesful results?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
I think @lightnwire is right. Check the fan. It possible there's manufacturers defect with the thermal compound. I mean if you know what your doing and frequently tear up laptops I believe this is what you want
[bağlı ürün eksik veya kapalı: IF179-010]
Here's a guide. I don't bother with Reddit anymore. But it does look like enough people are having this problem
https://m.youtube.com/watch?v=McQLU3cb65...
If it's brand new and you're not really into doing these repairs. Might wanna try using your warranty
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
You should check the fan to see if it is clear of dust and functions, if the fan moves too little air the heat builds up. Replacing the thermal compound may help if the fan is clean an functional.
Puan 0
1 Yorum:
I should mention that the laptop is brand new.
tarafından
Yorum Ekle
Hi, invariably if the fan is clogged then thermal paste will have degraded.
I believe that the silicone or other compound eventually evaporates or otherwise decomposes and
the result is flaky cooling.
Its also worth checking that the CPU is clean, sometimes they get fingerprints on the core and this can cause no end of problems over time even if it "seems" to work initially.
Usually just clean it with IPA and do the contact area on thermal pipe at the same time.
Also be aware that thermal compound containing silver can cause anomalies with silver migrating into the surrounding areas such as capacitors so you should be cautious and use only a tiny amount.
I once trashed a very expen$ive TV by using it on a HOT (hint: don't do this!)
Puan 0
Yorum Ekle
I’ve replaced my thermal paste on my XPS 13 a few days ago (2017 version, i7-8550u). It is still quite hot on idle (about 60°C, but that seems quite normal for a 13” laptop) but I won about 15°C on high load.
Compiling on 8 threads, it used to be 95°C hot @2,20 GHz and now it’s more 80°C @2.30 GHz.
In most scenarios it is either cooler or running at higher frequency. I’m very happy with it!
Puan 0
Yorum Ekle
Yanıtını ekle
Jack Cassidy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 31
Her zaman: 5,975
