Ana içeriğe geç
25 Eylül 2015'te yayımlandı. A1688/1633 modeli. Bu cihazın tamiri eski nesillerinkine benzer; tornavida ve kaldırma aletleri gerektirir. GSM ya da CMDA olarak / 16, 32, 64 yada 128 GB kapasiteli / Gümüş, Altın, Uzay Grisi yada Rose Gold (Gül Altın) seçenekleri mevcuttur.
2690 Soru Tümünü görüntüle
Bottom half of the screen is unresponsive.
I replcaed my phone screen about a month ago using one of the guiides on this website. Everything worked fine. Then out of no where the bottom half of the screen stopped working and I cant use the keyboard or anything. Im not sure what to do.
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Well a super temporary fix is to use landscape mode. Where did you get the parts from? If it was here, ifixit has an AMAZING warranty program
Here's the email for support. That's usual the best bet
http://help.ifixit.com/article/136-email...
Though their phone support has recently gotten better
http://help.ifixit.com/article/135-conta...
After that, if you haven't purchased from ifixit, I would contact whomever you've purchased it from, and see if you can't get a replacement
Bu yanıt yardımcı oldu mu?
Puan 3
5 Yorum:
This is the exact replacement screen i got....
https://www.amazon.com/gp/product/B01N2M...
Is there anything else I can do to fix it without having to replace the screen again?
tarafından
Probably not. The touch not working on the bottom half is characteristic of a faulty screen. It would probably be easy to get a refund if you bought it on amazon.
tarafından
It is now working. But I have to press a little hard to get it to respond. Could it be a partially disconnected wire or something???
tarafından
Nah, it can't be the ic this time. Apple moved em
tarafından
Try to reconnect the touch flex cable connector
tarafından
Yorum Ekle
my iPhone 6S bottom half isn’t working either. I cant even get into it because I need to do my password which  contains a 0 in it. when i press the 0 nothing appears to be working. what can I do?
Puan 3
2 Yorum:
The bottom half of my itel smartphone is not working. I don't know what to do
tarafından
how did you fix it
tarafından
Yorum Ekle
Mine is not working too what I have to do
Puan 1
Yorum Ekle
Yanıtını ekle
Jaredrett sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 40,834
