Ana içeriğe geç
Bu tablet, Temmuz 2013'te Asus tarafından piyasaya sürülmüştür. Model, ME173X olarak da adlandırılır. Tablette 7 inçlik bir ekran, microSD kart yuvası, MicroUSB yuvası ve kulaklık ucu bulunur.
Touch screen partially works
Touch screen has area where It doesn't work so I disconnect and reconnect more times the two flat ribbon cables which link touch screen to board but nothing!
Suggestions please?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@rickyleroy anytime you have part of a touchscreen that is not working, you most likely have a failed digitizer. Replacing it will fix your issue.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
If I work with virtual keyboard and I push down specific key, character is not lightened and no symbol is written while if I press it with more pressure another near character is typed.
I avoid this behaviour rotating tablet of 90 degree.
What other test can I do?
tarafından Paylaş
Where can find guide to replace touch screen for me173x?
tarafından Paylaş
I replaced touch screen. Now I noted in landscape mode it works fine while in portrait (vertical) mode, with Asus text in top area, the last bottom strip doesn't work where there the 5 five bottoms. If I rotate device of 180 degree the bottoms works so I suspect specific area has issue. What can I do?
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Riccardo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 30
Her zaman: 748
