Ana içeriğe geç
Home Flex Cable Replacement
I was fixing the batter (I have battery issues) when I accidentally bumped my phone off the counter and it tore (completely separated) the home button flex cable. I ordered a new home flex cable, but after doing some research- will I need to
A.) buy a new home button as well?
B.) will I lose my touch id function even if i keep the home button?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
hi Taylor, you must use it with your home button otherwise you will lose touch id function.
goodluck
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
If you tore this cable, you are okay with the touch id
But if you tore this cable, then you will need to buy a replacement button and you will lose touch ID but home button function will work
Puan 5
4 Yorum:
Great! I tore the flex cable up at the top, like the first image you've shown. I'll just be crossing my fingers until my flex cable gets here :)
tarafından
You are fine then, just use the original home button:)
tarafından
Taylor, you accepted the wrong answer ;-)
tarafından
@mayer at least she got an answer she is happy with ;-)
tarafından
Yorum Ekle
Yanıtını ekle
Taylor Fuller sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 5
Her zaman: 72
