Fix Lenovo laptop no sound problem
sometimes, you might deal with some errors on your Lenovo pc, sound issues are one of them. Every day, there are few Lenovo users coming online and they are complaining about the sound issue. the audio issue comes due to the several basic reasons. Which I am going to explain here.
Unmute the audio- When you can’t get an audio from your Lenovo pc, you should press the mute key, probably, you have silent the speakers on your laptop, that’s why you won’t hear from your Lenovo laptop.
So you push the unmute button on your keyboard, and then play a video or song.
Check the volume settings- You may have the low volume issue on the Lenovo laptop, so you should increase the volume and then play something.
Use headphones- let’s insert the headphones on your pc and then play something, let’s see if it is working perfectly fine or not? If it is working perfectly, it means there is something wrong with your speaker settings.
Setup the speakers as default- apart from this, sometimes, you may have Lenovo laptop sound not working issue due to the incorrect speaker, so you should choose your speakers as default and then play audio on your pc.
Driver update- apart from this, sometimes, you may deal with the sound issue on Lenovo laptop due to the driver issue, so you should update the sound driver on your pc, you can easily do it by visiting the device manager and click on the update driver next to the sound driver option.
Now your pc will update the driver from Lenovo server.
Reinstall new driver- If you still can’t get the audio from your Lenovo pc, you can terminate the current sound driver from your pc. Now download the new driver from Lenovo website and install it on your pc.
Factory reset – right after using these techniques, if your sound is still not working on Lenovo pc, you should factory reset the pc, but before doing this, you should take the back up. Once you reset the pc, all data will be gone from your device, so do not loose it from your device.
So these are the techniques to fix Lenovo laptop sound not working problem, in case, if you continue dealing with the sound issue, please visit askprob for more help.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
