Ana içeriğe geç
Repair guides and support for the seventh generation of Ford F-Series trucks. Models include the F100 (discontinued in 1983), F150, F250, F350, and others.
backfires when running and let foot off gas
is there such a thing as an anti backfire valve
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Typically, if it's backfiring out the exhaust on deceleration, it's because of a diverter valve for the air injection that is stuck or not receiving the proper vacuum signal. It could be dumping fresh air into the exhaust when it shouldn't be. The Idle: some possible causes are an idle set too high causing the EGR to open and close and perhaps float settings. It sounds as though it needs a little TLC. Often, the exhaust manifold warps causing the intake to warp with it and creates a vacuum leak along with the exhaust leak. Both manifolds are bolted together and are quite heavy to hang off the side of a motor without checking the torque of the nuts a couple of times a year. Someone sets the idle high to try to keep it running with a vacuum leak and the EGR activates. Kind of a cascade effect.
Bu yanıt yardımcı oldu mu?
Puan 5
Yorum Ekle
Yanıtını ekle
Andy McLoughlin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 19
Her zaman: 4,036
