Ana içeriğe geç
Crusher Wireless kulaklıklar için onarım bilgileri. Model numarası: S6CRW-K591. Amazon'da ilk olarak Ağustos 2016'da satışa sunulmuştur.
Bass lever not working
Resim
Not be confused these are NOT the original crusher headphones.
The bass lever on the left ear cup is not working. I tried taking it apart to look at the circuit board but everything looks perfect from the inside.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
I had this problem when I first got my pair as well. First of all, make sure the headphones are charged and that you are using the charger that came with the headphones if you are charging it for the first time. Then to fix the problem hold the power button (left side above slider) and the volume up button (top-right) at the same time for about 10 seconds, this will shut down the headphones completely without the voice saying “power off”. Then turn them back on and while listening to something, start moving the bass slider up and down and it should work again after a couple seconds
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
warrenspottedeagle sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 35
Her zaman: 2,285
