Why is the volume when playing from turntable very low
Volume is very low when using the Technics SL-1700 turntable
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi!
Turntables will output high quality sound only if they are connected to a pre-amplifier. These devices are different from normal amplifiers in that they only take the raw sound from the turntable and make it louder. Having the turntable only connected to a standard amplifier will not be the same, the sound will be played back at a very low volume.
Bu yanıt yardımcı oldu mu?
Make sure the turntable is connected into the phono input on the back and the dial is turned to phono on the front. Then there is a little button around the back (you might need a matchstick to press it as it’s countersunk from memory) which toggles the input between ‘normal’ and phono. You want it switched to phono. Good luck!
Son 24 Saat: 0
Son 7 gün: 15
Son 30 gün: 16
Her zaman: 899
