Ana içeriğe geç
Canon EOS Rebel T3, Canon'un giriş seviyesi DSLR fotoğraf makinesi serisi olan Rebel serisinin bir devamıdır. EOS 1100D ve EOS Kiss X50 adlarıyla da bilinen bu model, 12.2MP imaj sensörü ve DIGIC 4 görüntü işlemcisine sahiptir.
How to fix error 30?
I am getting this error message Shooting is not possible due to an error
I need help please.
Bu iyi bir soru mu?
Puan 0
1 Yorum
I need to I have camera canon 200d please help me error30 problem coming
tarafından Paylaş
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi!
The following text has been quoted from the Canon forums, someone had a similar issue and this is what the rep answered:
"Err 30" indicates that malfunctions related to the power source have been detected. Please follow these steps to attempt to resolve the issue:
Remove the battery from the camera.
Using a soft microfiber cleaning cloth, thoroughly clean any contacts that you are able to clean on the battery and inside the battery compartment. Do this even if the contacts already look clean.
Retry the battery in the camera.
If the error still occurs, please try an alternate battery. If the alternate battery produces the same results, your camera will require service to correct the issue."
Hope this helps.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
This can also be cause by contaminates and mainly shutter issues, see the many answers on this post:
Camera gets Err 30 message. How do I fix it?
tarafından Paylaş
It’s a faulty shutter.
tarafından Paylaş
Yorum Ekle
Also monitor its environment
that could easily create this issue.
Like leaving camera or any delicate device
in hot/damp enclosed vehicle.
They can be easily forgotten there,
exposed for days.
Good Luck.
Puan 0
Yorum Ekle
I'd first start with the other troubleshooting methods in the other answers, with checking the battery. However is seems like this error is often times caused by a bad shutter and there is a fair chance the shutter assembly will need to be replaced.
Definitely rule out any other possible causes first, but if it is deemed the shutter is the cause, you can use this guide to replace the shutter assembly. It's not the easiest repair to do, as it involves disassembling the majority of the camera (including the image sensor), but it is doable.
Puan 0
Yorum Ekle
Yanıtını ekle
Herve Dingi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 18
Son 30 gün: 54
Her zaman: 21,767
