Ana içeriğe geç
Asus ZenFone 2 (ZE551ML) is an Android smartphone manufactured by ASUS released March 2015.
How can I understand what's the problem?
My phone doesn't work anymore. It neither starts nor charge. The charge's led doesn't go on when i try to charge it. I changed the usb connector but nothing changed. Can someone help me to find the problem? ,
Update (08/30/2017)
No.
I tried various cable and charger.
It's happened in the night, battery was on 60% but in the day's after morning nothing work , no led's light while charging and no responding when I push the power button.
Bu iyi bir soru mu?
Puan 2
7 Yorum
Did you drop the phone? Does the phone charge when you use a different cable and power brick?
tarafından
Different battery perhaps?
tarafından
Do I have to try with a different battery? Can it be a motherboard's problem ?
tarafından
Yeah, it could be either the mother board or the battery.
tarafından
Is there no tools or methods to understand before what is not working or I can only try and try again till the solution?
tarafından
2 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi!
Use this guide to access the battery, the required tools are listed at the beginning of the guide I think.
This one will get you to the main board.
Asus ZenFone 2 Battery Görseli
Kılavuz
Asus ZenFone 2 Battery Replacement
Zorluk:
Zor
20 minutes
Asus ZenFone 2 Motherboard Görseli
Kılavuz
Asus ZenFone 2 Motherboard Replacement
Zorluk:
Orta
15 minutes
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Hello i have a problem with camera because fall down strangly and my lcd is broken and also when i want to call my screen shutdown and itis not turn on again thank u
tarafından
Yorum Ekle
Yanıtını ekle
Vincenzo Liguori sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 420
