Ana içeriğe geç
Sansa Clip+, SanDisk tarafından 2009 yılında piyasaya sürülen bir müzik çalardır.
Player stuck in refreshing media mode
Hi I have a Sansa clip plus 4gb. No idea what happened but one day I plugged into my laptop and my player restarted and stuck in refreshing media mode. I held the player to turn it off hard reset and no matter what its still stuck in the refreshing media mode.. Appreciate any advise at all as it's now as good as a junk of plastic =(
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
1 Yorum
That sounds really frustrating—I’ve seen a few cases where the Sansa Clip gets stuck in the refreshing media loop, and often it’s related to corrupted files or the memory card. Sometimes reformatting the internal memory through a computer or using the MSC mode instead of MTP can help. Have you tried connecting it in MSC mode and clearing out any recent files that might have caused the issue?
On a side note, I was recently reading about how small daily routines outside of tech issues can help reduce stres
tarafından
Yorum Ekle
9 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Great thing you came here!Well all you have to do is plug the player in your computer and delete these three files and they are named:MTABLE.SYS,RES_INFO.SYS,SYS_CONF.SYS.Reboot the player and you should be done!
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
I'm trying to do that, but I can't find the way to access those files on my Mac, any advice?
tarafından
Yorum Ekle
I had a similar problem: My sansa would insist on refreshing the media every time I turned it on. I found some info saying that there is a glitch in the flash card slot. I removed my sd card (never used it much anyway) and haven’t had the problem since. Since you don’t seem to have an sd card in it… and assuming you still have your sansa (this is an old question, it seems), if you hold the power button and the volume-up button for 20 seconds, you can force a reset. (Caution: holding the power and volume-down will give your sansa a factory-reset, wiping all of your music. Useful as a last resort.)
Hope this helps a little…
Puan 1
2 Yorum:
I did this and now my player won't turn on at all and it had been fully charged.
tarafından
And when I finally got it to turn back on it is still refreshing.
tarafından
Yorum Ekle
Totally can't even connect to pc!!!!
Puan 0
2 Yorum:
Yikes!Does it still turn on and do you have an sd card inserted?
tarafından
It does turn on but stuck in the logo mode.
No sd card inside.
tarafından
Yorum Ekle
Mine's stuck in the "Connected" mode, and won't turn off or connect back to the computer. Your problem could be the same, which would be caused by a broken connector port.
Puan 0
Yorum Ekle
Check this:
http://forums.sandisk.com/t5/All-other-M...
Puan 0
Yorum Ekle
Sandisk Sport Go SIMPLE SOLUTION TO STUCK IN REFRESHING YOUR MEDIA.
This works each and every time, no matter how much data youve transferred or how long the file names are. I searched everywhere to try to find out how to get the units to work that have many files on them, and then started experimenting. NO additional software needed. Here are the steps.
  1. Turn Sandisk GO off by holding the main front button until screen goes black.
  2. Plug the unit into your computer USB port using the cable supplied (other cables may not work).
  3. Sandisk is charging, and you can load files, remove, etc…just like any other file transfer.
  4. Unplug the Sandisk from the computer.
  5. The Sandisk will go into perennial “Refreshing Your Media” state.
  6. After a minute or so, turn the GO off like you did in step 1.
  7. Plug the Sandisk back into the computer but this time watch the screen. A brighter Sandisk shows up on the screen, wait 3 seconds (or until the Sandisk letters go slightly dimmer), and UNPLUG immediately from the computer.
  8. The unit will go directly to the folders screen and you’re good to GO!! (literally).
  9. Every time you turn the GO off and back on, it will be fine. The next time you plug it back into a computer to charge or load/unload files, you’ll have to follow the above procedure.
SIMPLE SIMON
Puan 0
Yorum Ekle
This method didn’t work. Unfortunately, I placed rare irreplaceable files on theSanDisk MP3 player and are unable to retrieve them. The player won’t play music and hangs in the “refreshing your media” screen. I’ve followed detailed instructions to no avail. I’ve worked on this problem for at least 6 months. I’d love to get my music files off this dead SanDisk. My disappointment level is so great, it borders on despair.
Puan 0
Yorum Ekle
there are many many wires that connect the mp3 to the computer but only some actually transfer data across. for example, the wire that comes with the product is good, but another one that looks identical may not work. Also, after a bit, the wire may get stretched or bent and cease working even though the mp3 player itself is still fine. you can sometimes buy a new wire and this will then work fine, at least it may help you be able to copy the files to the computer, and it may even allow you to then reboot your mp3 device or do something else to restart it successfully.
Puan 0
Yorum Ekle
It can be annoying when your player gets stuck in “refreshing media” mode, especially when you rely on it during travel. Sometimes this happens due to corrupted files or a failed sync. Try disconnecting it completely, then reconnect after clearing the media cache. Did you notice if it freezes only with certain files or every time you start it?
Puan 0
Yorum Ekle
Yanıtını ekle
Dex Sky sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 49
Her zaman: 9,499
