Ana içeriğe geç
Ağustos 2013'te piyasaya sürüldü. Z796C model numarası ile tanımlanır.
I can't move apps to memory card
I have the ZTE Majesty z799vl I need help with moving apps to SD card
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
2 Yorum
I dont even get that option...on any app
tarafından
I don't even See the option to move the app, and my phone keeps telling me I don't have any space left, yet I got a 32gb memory card in it
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You can move apps data to SD card by going to the settings/app then click on the app you want to move and in the app settings screen that pops up you will see a move to SD card button go ahead and push move to SD card.
It will let you move downloaded apps to the SD card if its gray then you can't move that app
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
How do you do that for the ZTE Majesty Pro (Z798BL)?
tarafından
I have only one app it is Verizon message plus and the rest were already installed and everyone who has this model phone has the same problem with storage space even with the 32sd card.where can we get help?
tarafından
i'm having the same problem just put in a 16 gb sd card and none of my app can save data to it. i have 2gb used already but when i select the show sd card nothing. Has this been solved?
tarafından
Yorum Ekle
Hi @home_1469 ,
Check whether the SD card has been mounted by going to Settings > Storage and see if it is listed as storage.
If it hasn’t been mounted here’s a link that shows how to mount a SD card in Android.
Be aware that when mounting that you have to reformat the SD Card so any data already on it will be erased.
Also note that when the SD card is available for storage that not all apps can be moved to the SD card. The move to SD card option on the app will be greyed out as the developer of the app has decided not set it to enable.
Puan 1
Yorum Ekle
Yanıtını ekle
Joseph sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 7,458
