Mode dial not functioning
The mode dial (pos 10 in pict.manual) appears not to function, after selecting a position, the camera remains in automatic mode, dial moves in a sticky way.
any solution?
Thanks
Paul
Bu iyi bir soru mu?
any solution?
Thanks
Paul
Bu iyi bir soru mu?
By using contact cleaner spray to the dials and buttons, after which I applied compressed air in order to dry the areas, problem was solved. Had to do it a couple of times
Bu yanıt yardımcı oldu mu?
Makes a lot of sense what you tried, although I would have used rubbing alcohol and no compressed air. Good job, you figured it out yourself.
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 34
Her zaman: 1,398
