Ana içeriğe geç
Güçlendirilmiş girişleri ve menteşeleri, soyulmaya karşı dayanıklı tuşları, sızdırmaz dokunmatik matı ve 9,5 saatlik pil kullanım süresiyle eğitim amaçlı kullanım için tasarlanmış sağlam bir Chromebook.
Why isnt the audio jack working?
I try connecting my headphones to the audio jack or well the entrance of the headphones, and it doesnt appear to be connected nor produce any sound on headphones
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
First check the audio buttons on your laptop to make sure the sound is not too low or muted. I sometimes clumsily forget that some FN key + audio button disables audio too. Have you tried your laptop with other headphones? If the same problem occurs, it is likely your audio drivers stopped working.
If you have an audio driver problem, try searching for one on lenovo's site:
https://pcsupport.lenovo.com/us/en/produ...
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
@kaykay 500 point level broken
tarafından
0_0 what does this mean?... :D
tarafından
Yorum Ekle
I am not entirely sure, because I've only worked on a couple of these, but I think the audio jack is just worn out. This seems to be a common problem for this laptop. If nothing is jammed in it, and it just feels loose, your next best option may be to buy a USB to audio jack adapter.
Puan 0
Yorum Ekle
possbily a cold solder joint on the speaker jack, a bad speaker Jack….eather way you will have to remove the mother board to check
Puan 0
Yorum Ekle
Yanıtını ekle
Sebastian Buritica sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 1,276
