Ana içeriğe geç
2003 model yılından 2007 yılına kadar olan birinci nesil Nissan Murano için onarım rehberleri ve destek.
Grounding Points on 2005
I have a 2005 Nissan Murano and I am having a few issues with sensors and my engine running really rich. I was advised by a mechanic friend that the issue could be caused by a bad ground. I am trying to find all the grounding points on my SL Murano. I have only been able to find 2. 1 below the battery and 1 off the timing chain housing.
Any suggestions? or could i just run new grounds from the battery?
Thanks,
Jarrett
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Sande Jarrett it would probably be easier to run a new ground than trying to find a bad one. Make sure you remove all paint and primer before applying a new ground and use some self tapping screws to attach it.
Now if you really, really want to know where all the ground points are, here is the manual for that :-) Nissan-Murano-Ground-Distribution.pdf
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Thanks!!! this is really helpful.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Sande Jarrett sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 19
Her zaman: 5,908
