Ana içeriğe geç
What is fault 49
What dose I need a service ,fault 49 mean .
Bu iyi bir soru mu?
Puan 2
13 Yorum
Hi,I have this fault on my fisher and paykel washer. The wiring harness looks fine,I replaced the inlet valve and the fault is still there. Any idea what else it could be?
tarafından
I too am in the same situation. would love further guidance
tarafından
Have you got the solution?
tarafından
I too am in the same position; water pressure there, no visually obvious blockage of the valves, wiring looks fine, resistance is measured but, still get the same fault code.
tarafından
Hi @rob_ldk
Have you checked that there is voltage be applied to the valve when it needs to be operated?
Be safety aware as the valve operates at mains supply voltage value i.e 120V AC or 240V AC depending on location.
tarafından
8 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
@stevew Error Fault Condition – Water Inlet Valve Fault.
Repair or Check – Unplug the washer from power. Reconnect any non secure wires on the water inlet valve. Replace the wire harness if it is found to be damaged. If the wiring is okay then measure the resistance of the water inlet valves using an ohm meter. If the resistance of each water inlet valve solenoid is not 60 to 62 ohms then replace the complete water inlet valve assembly.
Parts for Replacement – Water Inlet Valve Assembly or Wire Harness from here
Bu yanıt yardımcı oldu mu?
Puan 4
5 Yorum:
have replaced the water inlet valve but code is still coming up
tarafından
Resistance of both inlet solenoids are 57.7 ohms - Is that close enough?
tarafından
@bummers it should be coming close. Same issues? Code still coming up?
tarafından
@oldturkey03
Yes, same issues. I tested the voltage to each valve; my multimeter is only showing about 4 volts. Does that indicate a faulty controller board?
tarafından
@bummers 4 Volt would not be enough. Yes, it can be the board but check the wires and everything else as well.
tarafından
Yorum Ekle
49 fault definition is water valve
But it also relates to the pump circuit
If pumps overload you can get 49 fault
If the machine starts and operates then look for pump blockages
If the machine wont do anything then 99% of the time the circuit in the main board is blown up
Puan 0
1 Yorum:
If the board is no good is it worth getting technician to fix or just buy new machine
tarafından
Yorum Ekle
Yanıtını ekle
steve sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 51
Her zaman: 19,219
