Ana içeriğe geç
The first generation Honda CRV, produced from 1995 to 2001.
main fail safe relay location?
1999 Honda CRV where is the main fail safe relay location
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
i charged the battery and it started up i took the positive cable to reset the on board computer and now the code reader has nothing on it
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
charles medicinebull not quite sure what relay you are looking for. The only fail safe relay I know of is the one for your ABS and it is part of the pump/modulator including the pump relay. So, you need to be a bit more specific if those are not the ones you are looking for. It sounds like you may have gotten an OBD code and are inquiring. Let us know what exactly you are looking for.
Bu yanıt yardımcı oldu mu?
Puan 1
4 Yorum:
main fail safe thought maybe it was located under the dash board
tarafından
charles medicinebull some main relay or main fuse? What is the issue with your Honda?
tarafından
start the engine and it just turns no spark
tarafından
when i turn the key it just constant turning no spark
tarafından
Yorum Ekle
Yanıtını ekle
charles medicinebull sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 2,398
