Ana içeriğe geç
Repair guides for displays (or monitors) for computers or other devices with video output.
505 Soru Tümünü görüntüle
Can I Install in PS Capacitors With A Slightly Different Rating?
Recently, my monitor died. It refused to turn on, and after some research, I traced the problem to capacitors in the power supply. I bought a replacement kit on eBay, and installed most of it, and realized that it didn't come with all the right capacitors. One of the capacitors that I need to replace is rated at 220uF-25V, yet I recieved capacitors that are rated at 220uF-35V. Now my question is, can I install the 220uF-35V caps in place of the 220uF-25V's, or will I have to drive to RadioShack in a foot of snow and buy the right ones for 10X the price? The seller will not accept items that are opened, and since I installed about 1/2 of them, I don't think that will help either.
Bu iyi bir soru mu?
Puan 1
1 Yorum
no problem, that should be fine. go a head and replace those capacitors.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
As long as capacitors are rated at working voltage or more they will work. The 35 volt caps will work just fine in place of the 25 volt ones.
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
Correct answer +
tarafından
Yorum Ekle
Yanıtını ekle
Chris Green sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 5
Her zaman: 4,289
