emergency brake light switch
While emergency light on cruise control will not engage
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Enoch Vinnegar Jr there are a few possibilities. One being a bad parking brake switch or a bad switch in your brake fluid reservoir switch. This series has an issue with the wiring to the instrument cluster as well. Check on here for that. The image will show you where the parking brake switch is located
and this one
where the switch on your fluid reservoir is. You do want to check both of these switches for continuity.
Bu yanıt yardımcı oldu mu?
@oldturkey03 do you have a detailed document on how to remove the emergency brake assembly and driver's wiring harness under the dash? I may be missing information in my Ford tech service manual. I need to remove all this stuff to replace the floorpan. Same generation 2004-2008.
@Ben this is for the emergency brake 04 F 150 Parking Brake Still looking for the wiring harness.
@Ben see if you can get the 2006 manual from here Let me know when you have it so I can remove the link
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 78
Her zaman: 20,372
2 Yorum
Enoch Vinnegar Jr not quite sure what you are asking. What emergency light on cruise control?
oldturkey03 tarafından Paylaş
Was wondering where the switch that lights up the emergency brake light symbol on dash panel is located so I can change it. As long as this light is lite, my cruise control will not engage
Enoch Vinnegar Jr tarafından Paylaş
