Ana içeriğe geç
The HP Photosmart C3180 is an all-in-one printer.
cant figure out where the part goes
ok this is major urgency...i dismantled my photosmart c3188 seeing the guide on your site...and was able to reassemble it oo..but ...a part came off somewhere while dismantling i and i missed seeing its location and i have no clue where it belong....and the printer gives weird noise without it...plz plz plz help....i m attaching the photo of the part
image link
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Need a part number for feed roller assembly photosmart C3183, please.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
That part is a transmission axle from a gear in the right side at the bottom of the paper feed roller assembly, behind a oval like hole, that connects there with a gear in one extreme of this axle, the one that has the white piece. The axle sits in two U holes in the left and central walls, of the compartments that are under the printer head cleaner tray (see Step 34 in the guide for Feed Roller Assembly Removal, to remove this tray). The other end of the axle, that has a pinion, connects to a rack in the under side of this tray, in order to move the tray forward and back.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
You can see where this part go if you enlarge the first photo in Step 34.
There you see the part at the left and over the bottom line of the red square.
tarafından
Yorum Ekle
Yanıtını ekle
little angel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 170
