PS4 SMD HDMI Resistor on pin 13 replacement
I have tested this resistor and it appears to be no good. Does anyone know the replacement for this? I do not have access to a parts board.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
I finally found out what it is. It's 26k ohm. Thanks @tronicsfix.
Bu yanıt yardımcı oldu mu?
Hey Micheal,
I also have the same problem as well. I also got no value coming out that resistor. Just wondering if you have replaced it and did it work ?
Waiting for your reply
Mine actually ended up being a few loose pins. I replaced both the hdmi chip and the connector. Went over and over the pins and finally got them all connected well.
Its like @tronicsfix told me. You can test components all day long, but first you have to make sure you have good solder joints. Some of the pins look and feel connected but are not. Some additional pressure may be needed to verify.
Yea but what i mean is that i also get no reading from that resistor as well. I also replaced what you mentioned. But have you replaced or repositioned that resistor ? If so did it worked for you because i checked all the remaining resistors and they look fine using multimeter
@saadooo94 Are you 100% sure the HDMI port is soldered on correctly?
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 26
Her zaman: 5,425
3 Yorum
@tomchai and @tronicsfix know the most about game consoles here.
George A. tarafından
Thanks. I have seen lots of info about it going bad once the hdmi encoder goes, but nothing about what type of resister it actually is.
Michael M. tarafından
Anybody have any info?
