Ana içeriğe geç
The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
Power Mac G5 Dual 1.8GHz Deep CPU Hex screw removal
Hi all!
My power supply has just died, and I need to replace it myself. In doing so, I need to be able to remove the CPU & heatsink. I have removed all 6 2.5 mm Hex screws holding the Heatsink, but cannot remove the two middle, deep Hex screws. Hard to reach. I did recently purchase ifixit's 54 Piece Bit Driver Kit. It does reach the screws, though unfortunately, they won't budge at all. Should I try something like a Bondhus 13254 T-shape 2.5mm Hex wench instead? How can I remove these stubborn & hard-to-reach screws? How do the "PROS" do it? Frustrated that I'm stuck at a point not even reaching the power supply...
Any helpful suggestions are welcome. ("Get a new Mac" is not helpful...)
Thanks in advance!
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
I understand the frustration. So close yet still not there. I use a tool kit by Platinum Tools part number 19101. It has a neck that extends around 5 inches and has a thin neck like the one you use. You can get a little bit of help getting to it if your have the twin G5 Logos on the to of the heatsinks instead of the large single cover. You can unclip the G5 logo caps by just unclipping the two plastic clips at each end of each one. Just a small screw driver will do it and they will both just lift off. That will open the area up for you to get at it easier. That will give you a whole lot more room and you can most likely use the Extension that comes with your iFix it tool kit.
Good luck
Bu yanıt yardımcı oldu mu?
Puan 6
2 Yorum:
+ the voice of experience
tarafından
Hi mactech plus! Thanks for your input.
Well, ifixit's driver kit does have the extension, and I can reach the Hex screw-head easily. Problem is, the screws just won't budge at all. ifixit's extension is a flexible one which is useful at time, but seems to not take torque that much. Also, ifixit's driver handle is sort of polished round metal, and has no place the firmly grip & turn it. Your Platinum Tools 19101 look more promising as it has a solid extension AND lot's of place to grip & add some torque unscrewing.
I'll just look for a long T-handle 2.5 mm Hex driver.
Thanks again!
tarafından
Yorum Ekle
Hi
Anyone in the uk will struggle to find a suitable 2.5 hex wrench (I know i did)
I eventually found one at :
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?V...
they are about 9" long ;)
Puan 0
Yorum Ekle
Hi all again!
Well, G5 CPU/heat-sink removal SUCCESS!!!
And power supply removal SUCCESS!!!
I searched the web, and found Wiha Tools' 33437 T-Handle Hex 2.5mm x 200mm on Amazon, via Fargo Micro-Tools, for $3.90 + $2.80 S/H ($6.70 total). Nice & sturdy Red plastic T handle, AND nice long shaft. The deep hex screws were quite tight, though this tool did the job nicely. I was able to loosen the Hex screws enough (no need to totally remove any of the CPU Hex screws!), and my CPUs came out of the sockets, heat-sink all together, fairly easily.
Afterwards, I was also able to remove my dead power supply and as check the model & parts numbers, now ready to order a replacement. The power supply was indeed dead, as there was no click nor +5 volt trickle coming from it when plugged in. Dead...
Hope this helps others in a similar situation like me.
And also deeply hope I can fix my Mac myself, and use it again!
Wish me luck!
PS: Of course, I'd like to get a new Mac... ;)
Puan 0
Yorum Ekle
Yanıtını ekle
BostonUriKai sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 4,390
