Ana içeriğe geç
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
140 Soru Tümünü görüntüle
How much should I tighten brew head screen screw?
I removed the center screw holding the brew head screen, and cleaned the screen and exposed surface of the brew head. Then I put the brew head screen back in place with the center screw. I am unsure how much to tighten the center screw, as I am concerned that tightening it until the screw stops turning may tighten it too much and block water flowing from the center of the brew head. Can someone please tell me how much I should tighten the brew head screen center screw?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
It should be snug; tightening it too much will not stop water from getting through the screen, but having it too loose will allow grounds to get behind the screen and clog it up.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Thanks for your help!
tarafından
So there's no reason to make it super tight then?
tarafından
Yorum Ekle
Yanıtını ekle
Daniel E Montano sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 11
Her zaman: 394
