Ana içeriğe geç
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
2264 Soru Tümünü görüntüle
Touch ID does not work, But home button functionality works.
So I have an iPhone 7 128gb that i traded my jail broken 5s for. When i received the phone the screen was complete crap. So I decided to use another OEM iPhone 7 screen with it and everything was working fine. That display is cracked and I was/am just using it as a place holder. I ordered an "OEM" black screen for the phone because the one I was using is white. I got the screen, Put it on, and it boot looped. I looked at the back of the display and it had some metal tape over the touch ID chip so i took it off. When i booted the phone the home button was working but the touch ID functionality is not working. I switched back to the OEM screen and it still isn't. Any ideas? Did the metal tape short out the home button? Thanks for the help. I ordered a different screen, (Not the same one) and it should be here Friday. I will update you than.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The screw that secures the home button for the iPhone 7 is very finicky. You almost have to find the right amount of pressure (not too loose, not too tight) in order to get Touch ID/Home button functionality back to normal. Seeing as though this was a used phone that was opened up and compromised prior to you receiving it, you are taking shots in the dark, not knowing if the Touch ID/Home button was fully functional when you purchased it.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Thank you. Iv'e seen this places before, But did not know if it was worth trying. I will when i get home, As i am in school right now lol. I appreciate it.
tarafından
Yorum Ekle
Yanıtını ekle
Jimmy Feister sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 520
