Ana içeriğe geç
The Galaxy S7 Edge is the curved-screen variant of Samsung's 2016 flagship phone, the Galaxy S7. Announced February 2016 and released on March 11. Model SM-G935.
Reattach volume button, it fell off
As the title says. The buttom fell off randomly, i released after a few seconds of it going and managed to locate it on the floor. Just the metal piece fell off, to look at the device it is black and feels like rubber, jut so you understand whats actually fallen off.
Can i reattach this? And is the device currently still water resistant (I think the rubber is the watertight gasket)
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
1 Yorum:
this happened to me and all that fell out was the part that u touch and this black rubber with a little tiny stick thats also rubber
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
If you could post pictures we could probably give a clearer answer. But if it looks the way I think it will I don't think you'll be able to reattach it, even if you took the case apart. (Don't recommend doing this if you don't have to, very easy to break the back glass, plus it breaks the watertight seal.) If the button fell off he side I'm going to assume that the little bits of plastic/metal that hold it inside the case have broken off. If there are any little nubs sticking off either side of the button you could try inserting the button edge first and see if you can get it to pop back into place. Outside that you may be out of luck.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
The button is completely smooth and doesn't have anything that would seem to hold it in place on it. The place i got it from said they'd charge me £35 for a repair, or may cover it under warranty as you can clearly see the device hasn't been dropped (no clear impact marks)
tarafından
Did you get this fixed or whats up?
tarafından
Yorum Ekle
Same happened to me and I had to download an app called Volume Control
Puan 0
Yorum Ekle
Yanıtını ekle
Thomas sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 53
Her zaman: 13,553
