Ana içeriğe geç
RCA Voyager II, RCA tarafından üretilen 7 inçlik bir tablettir.
My screen is stuck on
when i turn on my screen it it stays on the screen that said voyager .
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 18
6 Yorum
how do you fix it
tarafından
I did all of that and all it does is turn back off it's still not working don't know what to do at this point HELP PLEASE…..
tarafından
Same here. Piece of junk
tarafından
when the tablet gets stuck on the rca screen how do I fix that
tarafından
how to fix a rca screen
tarafından
1 tane daha yorum göster
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Courtney Lord sounds like your tablet has issues with the Android operating system. You may have to try a factory reset by booting into recovery mode. Powered the tablet off making sure you have more than 50% charge on the battery. Boot into recovery mode by pressing and holding the volume up and power buttons. At the RCA logo screen, let go of the volume up button and you should see an android image. Press and hold the power button and tap the volume up button once more and you should be in the recovery mode menu. From here, you will need to use your volume up and down buttons to scroll and navigate to the wipe data/factory reset option and use the power button to confirm. When the process is done, go ahead and reboot and your tablet it should now be set to factory original settings.
Bu yanıt yardımcı oldu mu?
Puan 6
4 Yorum:
I did all the reboot and table hard reset but the keys will not work on my tablet
tarafından
Same thing happening to me
tarafından
I was dumb enough to buy a second rca tablet for my grandson only to have both of them stuck in limbo...the reset does not work on either one...everything was tried just as told but same screen...they will not go to any other screen...
tarafından
It worked thanks!
tarafından
Yorum Ekle
Press the power button, then volume up, then volume down. Then wait.
Puan 3
3 Yorum:
What if I don't have keyboard?
tarafından
You don’t need a keyboard. Use the PHYSICAL buttons on the tablet.
tarafından
It worked. Had to do it a couple times but it worked. Thanks!
tarafından
Yorum Ekle
What you are gonna want to do is,
  1. Press the power button.
  2. now press the volume up button
  3. lastly, press the volume down button.
  4. so basically, press the buttons going from up, to down.
Puan 0
1 Yorum:
How long does it usually take to get passed the voyager screen after I do all of that?
tarafından
Yorum Ekle
My rca touch screen is not working I factory reset and reboot and still the screen is still locked
Puan 0
Yorum Ekle
Yanıtını ekle
Courtney Lord sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 16
Her zaman: 17,828
