Ana içeriğe geç
27" display with 2560 x 1440 pixels resolution Thunderbolt & MagSafe cable attachments
160 Soru Tümünü görüntüle
Can I swap a LCD from a 27" 2009 iMac into a 27" thunderbolt display?
The LCD on my 27" thunderbolt display (LM270WQ1) burnt out about a year ago.
I haven't had the time to repair it and Apple told me it would be ~$600 to repair if they did it (of course).
However, on the 27" Thunderbolt display tear-down here on iFixit it shows that the 2009-2011 27" iMacs use the same display (LM270WQ1) but a different sub-model.
I've found a few of those displays on eBay, but before I pull the trigger I want to make sure Apple didn't do some stupid $@$* like change the ports so you can't do what I intend to. Unfortunately, Apple themselves won't answer the question despite discontinuing the product all together.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You can change the panel display from the LM270WQ1 SD B3 to any version.
You’ll need to change the backlight cable from the right to the left. The most important is the T-CON board LM270WQ1 SD B3, replacing SD A2 T-CON board.
i’m so very happy
For the LM270WQ1, set for only 2009-2011 for use with the Thunderbolt Display and the most important you have a T-CON board SD B3
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
Is there any video guides describing this? This would be awesome to see
tarafından
Yorum Ekle
I would be very hesitant - Even the iMac has different connections going to the board, from that display in that range of years.
Would be very surprised if they were compatible - Would be very unlike for Apple
Puan 2
Yorum Ekle
Sorry, no. The connectors are slightly different and therefore will not function if swapped. It’s pretty typical of Apple to do this and after coming to this conclusion I was not surprised. However, if you do want a replacement LCD that will work with your Thunderbolt Display you can buy one from eBay at the link below.
https://www.ebay.com/p/LG-27-Replacement...
Puan 0
6 Yorum:
@ajcooke01 is this different than the other from one year ago? Are you adding any different information to this?
tarafından
@oldturkey03 Not intending to make it look alike but I see what you mean now. I did my homework and researched it up though. I also gave a definant no too, so I kinda switched it up but not by too much.
tarafından
@ajcooke01 so are you adding any different information to this? This looks like a duplicate answer. Even a definite No is still only a comment at best
tarafından
@oldturkey03 Eh, not really.
tarafından
@ajcooke01 may be I am just to old to see where your answer is different. Care to point out where you are adding information to this.
tarafından
1 tane daha yorum göster
Yorum Ekle
Can I swap a LCD from a 27" Apple Cinema into a 27" thunderbolt display?
Puan 0
1 Yorum:
No, you cannot unfortunately
tarafından
Yorum Ekle
Yanıtını ekle
Harley Garner sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 1,041
