Stuck on start up page
It tries to start windows normally but goes right back to start up page I tried starting it every way it shows
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@zachman9807 sounds like a software issue and not a hardware related problem. I'd try a reinstall of the OS after booting in safe mode and checking for any devices etc. that might be causing an issue.
Bu yanıt yardımcı oldu mu?
i have a question if you are familiar with the EEE PC 1001HA? because i don't seem to have the ability to boot in to Safe Mode, and it runs windows XP by the way.
@mrchairmann just to make sure, for Windows XP to get into safe mode, once you see the black-and-white "Starting Windows" bar at the bottom of yourthe screen, you will have to repeatedly press the the F8 key until the Windows Advanced Options menu appears.Then you can select safe mode. Are you saying that you do not have that option? Do you still have access to your OS, I mean can you still use XP or are there any issues with it? Can you still access MSConfig?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 21
Her zaman: 164
