My Screen Pops up
Why is my Screen on my Tab Pro popping up near the cable connection to charge tablet? Please hel. Ty
Update (09/25/2017)
Thank you also home button is loose ty
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Looks like the battery might be swelling, be on the lookout if you decide to open it up for a swollen package in the middle of the case.
Bu yanıt yardımcı oldu mu?
My Samsung tablet is lifted on the corners and home button. Will not stay down when pressing. It turns on but is stuck on a message about google?? Would battery replacement fix this?
Thank you.
It could be the battery swelling up which is bad because it can lead to explosion and more problems.
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 22
Her zaman: 8,734
3 Yorum
Cynthia Avey could be that it is separating from the frame. It will help if you post some pictures with your question. That way we can see what you see. Use this guide Mevcut bir soruya görsel ekleme for that
=== Update (09/25/2017) ===
Thank you for the images. This could be the screen requiring replacement but it may also be the case starting to bend. Lay the Galaxy on a straight surface. If it is bowed in the center, it is bend. If it is not, it is your display needing replacement
oldturkey03 tarafından Paylaş
Not bowed in center only where the home button is, it is bowed only there.
Cynthia Avey tarafından Paylaş
Just found out it is the battery
