Ana içeriğe geç
22 Eylül 2017'de piyasaya sürüldü. Model A1864, A1897. GSM veya CDMA, 64 veya 256 GB depolama seçenekleri mevcut olup renk seçenekleri altın, gümüş ve uzay grisi şeklindedir.
iPhone 8+ and iPhone 7+ lcd
iPhone 8+ display compatibility and iPhone 7+?in Ches the difference
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
6 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Here's the latest info on the iPhone 8:
iPhone 8 Sökümü
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Both of them can't work well on each other. I write an article "What’s the difference between iPhone 8 and iPhone 7 LCD screen?", if you want to see it please see my profile then visit my blog. Also you can watch the video here:https://youtu.be/KxFovnbcY3E
Puan 1
Yorum Ekle
Be VERY AWARE of chinese sellers on eBay trying to pass off iPhone 7 Plus screens for iPhone 8 Plus. They nearly look identical.
Puan 1
1 Yorum:
7 has hooks at the top and 8 has metal brackets
tarafından
Yorum Ekle
They looks similar but they can't work well on each other or say it not full functioning on each other,
Puan 1
Yorum Ekle
No, you wouldn't be able to interchange displays between generations of iPhones. The 8 uses a 3 channel, temperature sensitive light sensor.
The 7 uses a single channel, light only sensitive sensor.
The ribbon cables are also likely different.
Puan 0
Yorum Ekle
Yes you can put the iPhone 8 + digitizer on a 7+ iPhone.
And it will work just fine, only the display.
You need to use the orignal homebutton and sensor/frontcam cable.
The screws in the bottom wont fit unfortuanately
Puan 0
1 Yorum:
It can work but will have issues
tarafından
Yorum Ekle
Yanıtını ekle
Alex Pro sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 31
Son 7 gün: 48
Son 30 gün: 59
Her zaman: 5,442
