Ana içeriğe geç
Apple Extended Keyboard'un halefi olarak 1990 yılında piyasaya sürüldü. Efsanevi ALPS dokunsal anahtarları (tactile switches) veya Mitsumi standart mekanik lineer anahtarları kullanan M0312 ve M3501 modelleri üretildi.
Removing the metal frame
Hello there,
The ^/ ° key went dead, so I soldered a new ALPS tactile switch onto the back - and all of a sudden two more keys refused to function: a & </>
While reassembling the AEK I noticed a copper strip, about 52 mm x 2mm with a drilled hole at one end of it, which hadn't been there before and presumably fell from somewhere between the metal plate and the mother board.
Is there a way to separate the metal plate from the AEK's mother board?
Thank you
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Resim
Is this what you are trying to do?
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Probably a late response but yes, the metal plate can be removed. The only thing holding the steel plate to the motherboard are the switches.
Just have to desolder every single switch .
Once desoldered, just lift the plate, or take out each switch one at a time. Use Rosin Flux and a clean soldering iron tip to avoid damaging the pcb, since it is very old at this point and it is very easy to raise these old solder pads (once you do, they’re gone forever).
Course, that’s a huge hassle.
Puan 0
Yorum Ekle
Yanıtını ekle
jirudo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 19
Her zaman: 690
