The HP Officejet 6600 Inkjet Multifunction Printer is a 4-in-1 device that can print, scan, copy and fax.
darlenebarber54 @darlenebarber54
İtibar: 1
Gönderildi: 26 Eyl 2017
will not print from computer
Bu iyi bir soru mu?
5 Yorum:
Hi,
Has it worked OK before when connected to the computer?
Does it work OK if you try to copy or scan a document using the printer's control panel?
If it works when using the printer's control panel, what make and model of computer is it connected to and what OS is installed in the computer?
jayeff tarafından 26 Eyl 2017
Printerhead? what do you mean? or are you trying only to print from your pc?
jbermudez27 tarafından 26 Eyl 2017
Yes. It is not printing from computer or copy or fax
lorenzo.walker tarafından 17 Oca 2018
Hello jayeff,
It is not printing from computer, or fax, or copy. I have replaced all ink cartridges in printer
Hi lorenzo.walker,
Have you tried a 'Clean Printhead"operation from either the printer's control panel or the HP printer software in the computer?
On the printer press the Right Arrow > Setup > Tools > Clean Printhead.
Do it 2-4 times to see if it starts to print.
jayeff tarafından 17 Oca 2018
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 60
Hi,
jayeff tarafından
Hello jayeff,
Hi lorenzo.walker,
jayeff tarafından
