Ana içeriğe geç
1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
192 Soru Tümünü görüntüle
Plastic on battery pods.
The replacement battery came with clear plastic covers on each of the battery pods. Do I need to remove those before I install. Looks like they should, but I couldn't find anything that referred to them. They don't come off super easy.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
When I began to do this on 1 of the 6 the replacement battery pods, it slightly puffed up. I had only pulled up about a 1/4 of the clear covering from the battery.. So is it bad or unsafe to use now??
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Depends on what you mean by puffed up. Sometimes I get batteries with like vein marks on them? Is it like that?
When pulling these protective plastic films make sure to hold the battery cell in place when doing so.
tarafından
Yorum Ekle
No vein marks.
Pod puffed up like 2mm, no longer hard like other 5.
Puan 0
2 Yorum:
OK, so if one of the battery cells are puffed up like that they are not safe to use. It will usually expand pretty quickly later on and you would need to get the battery replaced.
tarafından
Thanks a lot for your help! ...Very nice:)
tarafından
Yorum Ekle
Yanıtını ekle
Jeff Buck sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 10
Her zaman: 1,216
